Thread: Copper Tube
    2010-01
    5
    Exclamation Copper Tube
    I am looking to route my first water system in Revit and noticed there are no fittings for copper tube. Are there websites that offer these for free or am I SOL? Thanks!
    AUGI Addict mattw's Avatar
    2002-06
    North Central CT
    1,007
    Default Re: Copper Tube
    No, you're not SOL. You just have to set up the various styles that you want. Expand the FAMILIES tree and scroll down to PIPES. Underneath PIPE TYPES you'll have to PVC and STANDARD as the two default types. Right-click on one, select DUPLICATE and rename it to COPPER (or whatever material you want). Then right-click on the COPPER pipe type and select PROPERTIES. From the MATERIAL drop-down select copper. Change any other values you want.
    You'll have to do the same thing for the fittings as well. But if you do this in your template you only have to do it once and it'll be available to any job from that point forward. Also, you can transfer project standards between files.
    Hope this helps!
    Matt
  1. 2011: Routed Systems copper Tube & Pipe Style question
    By jmenoche in forum Inventor - General
    Last Post: 2010-06-15, 01:24 PM
  2. Copper Lanterns
    By TimShelton in forum ACA/AMEP Styles Library
    Last Post: 2009-04-17, 07:23 PM
  3. Copper Piping
    By cadragon in forum Revit MEP - General
    Last Post: 2009-01-26, 09:27 PM
  4. AutoCAD 2006 - Draw a Tube along a Path to make a 3D Tube
    By omorah in forum AutoCAD 3D (2006 or below)
    Last Post: 2007-05-17, 01:40 PM
  5. Copper Pipes
    By flaviusb in forum Revit MEP - General
    Last Post: 2006-08-01, 08:00 PM
