Thread: customize edit alignment dialog box
    100 Club sturner's Avatar
    2004-05
    Maryland (sigh)
    149
    Cool customize edit alignment dialog box
    this maybe someting only autodesk can do but...
    is it possable to customize the edit horizontal alignment dialog box to display:
    STA , EGR, EGL, EGC, FGC
    instead of the default station, norting, easting??
    thanks,
    ACAD 2006 & 2009 LDD & Civil
    Windoz XP PRO(SP2)
    Debian 4.0
    2001-10
    Arizona
    2,337
    Default Re: customize edit alignment dialog box
    Quote Originally Posted by sturner
    thanks,
    Nope, not going to happen in Civil Design because the data
    you are after; other than STA is all in the Vertical alignment database.
    I don't see this as a function of the Edit Horizontal alignment in
    Civil 3D either. This despite the fact that the two alignments
    are dynamically linked to each other and the terrain model?
    I think you might be able to do this in or with an XML style sheet
    for a report although I don't see that serving your needs.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2004-05
    Maryland (sigh)
    149
    that's what i thought, i got the 'at my old job' bit this morning. so i thought i'd throw it out there.
    thanks mike
    Windoz XP PRO(SP2)
    Debian 4.0
  1. Alignment Dialog box not opening
    By KJBIKE7 in forum AutoCAD General
    Last Post: 2008-01-30, 08:06 PM
  2. MText edit dialog box comes up rotated
    By kwdsku in forum AutoCAD Civil 3D - General
    Last Post: 2006-01-23, 07:51 PM
  3. Alignment Librarian Dialog Box
    By chris.johnson in forum Civil 3D - Civil Design Companion - General
    Last Post: 2005-03-26, 12:35 AM
  4. Edit View Dialog Box
    By rjohnson.72922 in forum MDT - General
    Last Post: 2004-09-01, 11:53 PM
