Results 1 to 8 of 8
Thread: SCREEN MENU PROBLEMS???
    2009-09
    fort worth, tx
    23
    Question SCREEN MENU PROBLEMS???
    my autocad 2010 crashed earlier this morning while i was in the middle of doing some stuff here at work. so i opened it back up and finished my drawing (i was in 3D mode). so i changed my layout back to "autocad classic" and noticed that all my menus were gone. i went to the options and made sure it was still selected and it was. the picture shows what i'm talking about. but that didn't work, so i repaired my autocad and opened it back up, and it was still there. has anyone come across this or know a way to fix this? not sure why it did this.
    0,0,0 The Origin
    8,570
    Default Re: SCREEN MENU PROBLEMS???
    I didn't know it was possible to undock the screen menu. Have you tried dragging it to the screen top-right corner?
    2009-09
    fort worth, tx
    23
    Quote Originally Posted by jaberwok View Post
    yes sir. tried dragging it back to the side and re-docking it. nothing has worked. when autocad crashes, you know the left hand side that gives you the recovery list of drawings? well, that's what it looks like whenever it's docked back in place. screen menu stays the same, just docked instead of free floating. i'm so lost on this. i've never seen this before. it's almost as if those files are missing or something.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Have you modified the OOTB menu / CUI? If not, you might try saving your current CUI file then copy of the OOTB CUI from the UserDataCache folder.
    2009-09
    fort worth, tx
    23
    not sure what "ootb" menu is. but cui, i haven't touched it. didn't touch anything when all that happened. figured that i would just save over it by remaking my workspace with the original autocad classic workspace. i'd still like to know what caused this or how it happened.
    2002-01
    jUSt Here (a lot)
    9,105
    OOTB = Out of the Box or the original file from the installation
    2000-01
    Seattle WA USA
    5,859
    Exclamation Re: SCREEN MENU PROBLEMS???
    No need to do a manual copy these days. Simply go into the CUI editor, select the OOTB CUIx node, right-click and select Reset.
    This replaces the selected CUIx with the OOTB version from UserDataCache.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2002-01
    jUSt Here (a lot)
    9,105
    Quote Originally Posted by RobertB View Post
    Good to know.
  1. How Can I realise the screen-menu in the picture?
    By 740176597380946 in forum ARX
    Last Post: 2013-05-17, 01:31 PM
  2. Wonder where the old DOS screen menu went?
    By dbanker in forum AutoCAD Tips & Tricks
    Last Post: 2011-03-14, 04:15 PM
  3. Screen menu
    By RSARELLANO in forum AutoCAD CUI Menus
    Last Post: 2007-10-02, 08:44 PM
  4. Restore Screen Menu
    By edward.kohles in forum AutoCAD CUI Menus
    Last Post: 2006-03-17, 06:23 PM
  5. Screen menu to die - what do you think?
    By Steve Johnson in forum AutoCAD Wish List
    Last Post: 2005-06-15, 03:04 AM
