Thread: polyline to viewport
    2009-09
    32
    Default polyline to viewport
    Using Convert Object to Viewport command when I convernt a closed polyline to a viewport and then select that viewport in the Properties dialog box CAD shows 2 objects selected one is the viewport and the other one is the polyline itself. I think after converting the polyline to viewport it should be a single object only and not two.
    Secondly if their are 2 objects then why the viewport is not visible and only the polyline is visible. Is the viewport some invisible entity that we cannot select separately without selecting the polyline. If they are two objects how to separate them from each other.
    Please Explain.
    Thanks.
    100 Club Paul Munford's Avatar
    2006-08
    London
    177
    Default Re: polyline to viewport
    This behaviour is correct. The polyline is the clipping path for the viewport. If you delete the polyline the viewport will go back to being un-clipped. Why would you want to separate them!
    2004-08
    Hartford, Michigan
    3,192
    Quote Originally Posted by mdsalman2003 View Post
    Please Explain.
    Thanks.
    This is the way it has always functioned. Iif you want a rectangular viewport, use mview, and draw the rectangle. When you want odd shaped viewports (i.e. circle), select the object option from mview and click on the object. When selected, in 2010, it shows the viewport properties by default, but it is still one of 2 objects, the circle cannot be separated from the viewport, if you try to delete it they both go away. The circle is the clipping boundary for the viewport. In the properties palette, you can modify both objects independently of each other by selecting the appropriate object from the pulldown at the top.
    Christopher T. Cowgill, P.E.
    AEC Collection Civil 3D 2018
    Windows 10
    0,0,0 The Origin
    8,569
    To put it another way - every viewport is rectangular. If it appears non-rectangular it has been clipped so you need both the viewport and its clipping object.
    John B
  1. Replies: 1
    Last Post: 2014-11-04, 03:32 PM
  2. Replies: 1
    Last Post: 2012-12-19, 02:31 PM
  3. Replies: 14
    Last Post: 2007-09-10, 05:01 PM
  4. Replies: 16
    Last Post: 2007-05-09, 09:23 PM
  5. Smaller Viewport to hide / mask part of a larger Viewport
    By thomas.stright in forum AutoCAD General
    Last Post: 2006-04-05, 11:03 PM
