Thread: Memory Can Not Be Read
    2004-11
    3
    Question Memory Can Not Be Read
    My office has started using AutoCAD 2004/05 recently. Slowly moving into it. Many projects were completed in R14. Lately, we have been receiving an error message when exiting R14 that says:
    "The instruction at 0x008b3b9e" referenced memory at 0x051421f4". The memory could not be read." Could this have something to do with 2004/05? or is there a bigger problem here?
    Can't figure this out-tried many attempts. Any suggestions would be greatly appreciated!
    2001-03
    13,499
    Default Re: Memory Can Not Be Read
    Hi
    Check out the following Technical Documents on the Autodesk web site under the Knowledge Base section -
    ID: TS79421 - Application error when exiting programs after installing AutoCAD® 2004 on Windows NT® 4.0
    ID: DL404046 - Unicon.reg File: Application Error Resolution
    Have a good one, Mike
    2004-11
    3
    Is this applicable to Autocad R14 as well?
    Thanks again
    2001-03
    13,499
    Hi
    The links provided are for Autodesk 2004 based products.... have you tried installing the fix for those products, then seeing if that prevents the error occurring in the first place?
    2004-11
    3
    Smile Re: Memory Can Not Be Read
    Thanks Mike.
    Researching this further, we have found out that this is a Windows xP Service Pack 2 issue. Program works fine-however-we are waiting to get the "fix" from Microsoft.
  1. 2011: Memory Crash (running out of memory)
    By gfreddog in forum AutoCAD General
    Last Post: 2012-04-19, 08:16 PM
  2. Replies: 4
    Last Post: 2011-09-13, 12:17 PM
  3. Question about memory and peak memory
    By gbelous in forum Hardware
    Last Post: 2010-04-02, 01:48 PM
  4. Replies: 3
    Last Post: 2009-10-03, 04:21 PM
  5. Attempted to read or write protected memory?
    By c-hawk in forum Revit - API
    Last Post: 2009-08-12, 02:32 PM
