Thread: Link a CAD file problem
    100 Club Silleke's Avatar
    2007-03
    131
    Default Link a CAD file problem
    I linked an AutoCAD file to a current Revit project. I can control the visibility and can set it to foreground or background. But after some days later, I was not able to control the setting either to foreground or background. Clicking on the linked file will not show the option bar to set it as foreground or background. Is this a bug in Revit Structure 2010?
    The only work around is to remove the linked CAD file and re-link it again.
    Any thoughts about this problem?
    _______
    Silleke
    2007-03
    131
    Default Re: Link a CAD file problem
    The option "foreground or background" will NOT work in case you did not check the "Current View Only" option.while linking the Cad file. So be awared of it.
    Silleke
    2007-03
    Melbourne, Australia
    278
    Because it is then imported as a 3D import, and will only be visible if it is within the view range of the view.
    Would be nice if it defaulted to "current view only" it will keep it checked after you set it in that session.
  1. ole link problem
    By clintonc in forum AutoCAD General
    Last Post: 2011-06-29, 09:33 PM
  2. Replies: 3
    Last Post: 2009-10-20, 12:28 AM
  3. Replies: 4
    Last Post: 2007-03-06, 02:28 PM
  4. My first DST Template - Link DWS file to DST file
    By madcadder in forum AutoCAD Sheet Set Manager
    Last Post: 2007-01-08, 04:35 PM
