Thread: System parameters in a generic face-based family
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,825
    Question System parameters in a generic face-based family
    I'm currently working on a safety switch family. I want it to be face-based so I started with the Generic Face-Based template.
    However, this family is really electrical equipment. So I want all the system parameters for electrical equipment to be in this family. I cannot figure out how to get all the system parameters from the Electrical Equipment template into this family.
    R. Robert Bell
    Design Technology Manager
    S P A R L I N G
    Opinions expressed are mine alone and do not reflect the views of Sparling.
    2009-02
    Houston
    686
    Default Re: System parameters in a generic face-based family
    When you change the category from Generic Model to Electrical Equipment (from the Family Category and Parameters dialogue) it should automatically pull in the system parameters you want. It seems to work on first glance, but maybe it misses one or two. I didn't compare one-to-one.
    2001-08
    Dallas TX USA
    5,825
    In 2010, there are a bunch that are missing, especially from the Electrical - Loads group.
    I have found that if I duplicate the parameter name, it appears to be treated as the system parameter, i.e. I can use it in a schedule, but I can edit it using the Modify button, unlike the "real" system parameter.
    R. Robert Bell
    S P A R L I N G
    2009-02
    Houston
    686
    Quote Originally Posted by RobertB View Post
    I tested it in 2010 and I don't seem to be getting the same result. Is it possible you are not matching the "Part Type" parameter in the Family Category and Parameters dialogue? Each Part Type comes with a different set of system parameters.
    2001-08
    Dallas TX USA
    5,825
    Talking Re: System parameters in a generic face-based family
    Quote Originally Posted by cporter.207875 View Post
    That's the ticket. That explains why some come in and some don't.
    However, I do find it odd that I can create a parameter that has the same name as a system parameter, and it still schedules.
    Sample:
    Start with generic face-based.
    Change family category to electrical equipment.
    Change part type to equipment switch.
    Go to family types dialog.
    Note there is no "Enclosure" parameter under Electrical - Loads.
    Create that parameter.
    Create a schedule for electrical equipment and the manually created Enclosure parameter can appear in the schedule as a field.
    Mind, I'm not complaining, I rather like it. But the interface is misleading. It would appear to be treating it as a system parameter for scheduling, but it is not treating it the same way Voltage is in the dialog, e.g. you cannot modify Voltage but you can Enclosure.
    R. Robert Bell
    S P A R L I N G
    2009-02
    Houston
    686
    Yeah, this is weird but could be useful in some respects. Interesting find!
  1. Face-based or generic, using linked models?
    By JoelB in forum Revit MEP - Families
    Last Post: 2010-05-04, 05:17 PM
  2. Face Based generic Model vs. window for skylight
    By WYSIWYG-BIM in forum Revit Architecture - Families
    Last Post: 2010-03-25, 11:23 AM
  3. Unable to link parameters in face based family
    By vennix in forum Revit Architecture - Families
    Last Post: 2009-10-02, 07:53 PM
  4. How do you changing a wall based family into a face based one
    By speedfreak5150 in forum Revit Architecture - General
    Last Post: 2009-07-13, 05:21 AM
  5. Generic Model Face Based Origins
    By jspartz in forum Revit Architecture - General
    Last Post: 2007-02-12, 10:32 PM
