Thread: Alignment Labeling - C/L Grade and Distance
    2010-02
    10
    Default Alignment Labeling - C/L Grade and Distance
    Hi folks,
    Wondering if anyone can help me set up a label to show C/L road grade and distance between PVI's?
    I've attached a picture of how we typically display this information on an overall roads plan. Looks simple right?
    The best I was able to come with was to extract a feature line (at C/L) from the corridor, then label that with 'distance and grade'. Trouble with that is when I create the feature line, it is created as multiple segments, not one segment from PVI to PVI, so the length is all wrong.
    2006-12
    Loveland, CO
    734
    Default Re: Alignment Labeling - C/L Grade and Distance
    These are the only properties from a profile that you can add to an alignment label via a reference component. http://screencast.com/t/ZTQxNDhhM If you can't display it using these values, then I don't know of a way to do it. If you can program via .net or .vba, then I'm sure it can be done.
    Brian J. Hailey PE
    CAD-1
    Civil3D PLUS My blog
    At Your Desk Training
    2007-08
    67
    Quote Originally Posted by kevin.jackman View Post
    Hi folks,
    Take a look at labeling Profile Geometry Points with the Station type labels. Use the <[Distance to Next PVI(Uft|P3|RN|AP|Sn|OF)]> <[Grade Out(FP|P2|RN|AP|Sn|OF)]> or Grade In depending on how you want to label it. http://screencast.com/t/NDVhZmQxY
    2006-12
    Loveland, CO
    734
    Once again I stand corrected. That's what I like about these discussion groups, I'm always learning new things!
    Brian J. Hailey PE
    CAD-1
  1. Labeling bearing and distance in Autocad Land Desktop 2009
    By kberlinsky703020 in forum Land Desktop - General
    Last Post: 2015-07-10, 12:44 PM
  2. Deflection angles labeling in alignment
    By sacprasanna383394 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2012-06-25, 04:20 AM
  3. labeling northing & easting on an alignment
    By Maverick91 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2012-03-29, 04:02 PM
  4. A though question on alignment - station labeling
    By ebarlevi in forum AutoCAD Civil 3D - General
    Last Post: 2007-10-16, 12:04 PM
  5. Alignment / Pipe Labeling
    By avn in forum AutoCAD Civil 3D - General
    Last Post: 2007-05-16, 07:34 PM
