Thread: Exported Walkthrough
    2008-01
    Perth WA
    294
    Default Exported Walkthrough
    Hi All,
    We have just exported a walk through to an AVI file.
    A part of our post production is to use this animation with some still renders to create a show reel.
    What has happened to us today though is when the walk through is placed into the after effects program the background is removed. So in effect we have a model sitting in black space.
    Has this happened to anyone before? Is there a setting we are missing in the export process?
    2008-03
    14
    Default Re: Exported Walkthrough
    Never tried it or worked with aftereffects but my guess is that it is reading the sky as transparent - like an alpha map with max. Could you not drop a white layer (or whatever you want your sky to be) behind it in AE.
    2008-01
    Perth WA
    294
    Yeah, you are spot on. It is an alpha channel that does not translate to being compressed.
    Have to use a different file type, which by the way, Revit does not export to!!!!.
  1. 2014: Revit exported to CAD
    By madeel495827 in forum Revit - Platform
    Last Post: 2014-03-10, 08:47 PM
  2. Layers from RS in the exported IFC-model?
    By m.knutsson714642 in forum Revit Structure - General
    Last Post: 2011-12-21, 12:55 PM
  3. trusses don't appear in exported DWG
    By mark.130012 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2010-07-13, 02:01 PM
  4. Shadows exported to DWG
    By Dimitri Harvalias in forum Revit Architecture - General
    Last Post: 2007-03-07, 07:50 PM
