Thread: Text not Showing
    I could stop if I wanted to STHRevit's Avatar
    2008-01
    Perth WA
    293
    Default Text not Showing
    OK, I have searched the forum and found a couple of posts on this. I thought I understood how to work it, but alas, no. I can not get it to work for me.
    I have created a mullion to use for my concrete wall panels in a curtain wall.
    What I want is to assign some text to this mullion so as they are created in the model a "PJ" (panel joint) annotation will be created at the same time.
    I have tried creating a Generic annotation label and inserting it into the mullion family, but no dice.
    Any Ideas? perhaps a step by step tutorial on this. It is driving me nuts.
    Glad it is Friday.
    Andrew
    STH BIM Manager
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    Default Re: Text not Showing
    Annotation inside of families do not come through to projects.
    2006-01
    4,516
    Generic Annotation families do. Thats how Electrical Outlet symbols ar emade, and also how our Line Based Egress Calculator is built.
    But the thing with Mullions is theyre not families, theyre profiles in system families. ive never tried it, so i dont know if thats the issue or not, but it may be.
    If i remember ill try when i get in...
    The above post is by a user not frequenting the site. Questions regarding post:
    Send to: aaron@aaronmaller.com (include text of post). Thanks.
    2008-01
    Perth WA
    293
    Cheers Aaron.
    I didn't even think of than. You could be spot on.
    Andrew
    STH BIM Manager
    2006-10
    Cape Town
    94
    I am realy battling with this. Perhaps someone can help. I have made a line based model for drawing pipes, trunking and ducts in running lengths. I want to add the possibility of having a parametric arrayed abbreviation such as "110mm dia" inserting automatically on the pipe as I draw it which is in itself goverened by a type parameter. I have loaded my parametric arrayed line based detail component into which I have loaded my generic annotation for the abbreviation into the model family but the text does not appear regardless of whether it is a parameter or not. Any way of solving this?
  1. Text not showing up in PS
    By ccook79 in forum AutoCAD Annotation
    Last Post: 2010-09-09, 02:34 PM
  2. showing text in models
    By aaronwsmith in forum Revit - Platform
    Last Post: 2007-10-29, 11:32 PM
  3. showing text in models
    By aaronwsmith in forum Revit Architecture - General
  4. Oven Text Showing Through
    By bclarch in forum Revit Architecture - General
    Last Post: 2003-09-29, 08:42 PM
