Thread: Using DVB's for 32bit and 64bit Windows 7
    2007-03
    65
    Default Using DVB's for 32bit and 64bit Windows 7
    Any thoughts? Can it be done? Should it be done? Adverse affects?
    All comments are appreciated.
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,829
    Default Re: Using DVB's for 32bit and 64bit Windows 7
    You will need separate DVB files for each OS. Otherwise the 32-bit DVB files, loaded in the 64-bit OS, will update references and attempt to make you save the changes.
    Not to mention the performance issue.
    Not to mention the fatal crash that will eventually "infect" you when you attempt to load code during S::Startup. (You don't start out that way, but eventually it happens.)
    It is time to move to .NET.
    R. Robert Bell
    Design Technology Manager
    S P A R L I N G
    Opinions expressed are mine alone and do not reflect the views of Sparling.
    2007-03
    65
    Quote Originally Posted by RobertB View Post
    Thought as much.
    I don't think I use code during startup... Could you be more specific.
    How does one begin in .NET? Is there a coding program like vbaide and vlisp?
    2001-08
    Dallas TX USA
    5,829
    Quote Originally Posted by ccaron View Post
    At some point, not immediately, attempts to load VBA code using Visual LISP or even the VBALoad command, during the time S::Startup is running, will cause AutoCAD 2010 to fatally crash. So if your S::Startup function is using (vla-LoadDVB) or (command "._VBALoad") you run the risk of developing the fatal crash. Once you get the fatal crash, you will have it until you wipe and reinstall the OS.
    http://forums.augi.com/showthread.php?t=52913 for starters.
    R. Robert Bell
    S P A R L I N G
    2007-03
    65
    OK, yea I reviewed all my startup lisp files and I don't have and DVB calls. I have stayed away from that because I don't like mixing apples and oranges.
    It doesn't seem like my code is so complex as to cause issues. BUT, I will begin the transfer...
    VB.NET... Lovely!
    Thanks for the help
  1. 32bit vs. 64bit
    By fwp in forum Revit - API
    Last Post: 2009-12-19, 06:08 PM
  2. Revit 32bit vs. 64bit
    By tknapp in forum Revit - Hardware & Operating Systems
    Last Post: 2009-11-16, 08:05 PM
  3. Install 32bit and 64bit together?
    By Andre Baros in forum 3ds Max - General
    Last Post: 2008-11-04, 01:15 PM
  4. 32bit or 64bit Inventor
    By Bunny in forum Inventor - General
    Last Post: 2008-10-19, 02:07 AM
  5. Studies on 32bit vs. 64bit
    By Dave Lewis in forum Hardware
    Last Post: 2007-10-04, 06:29 PM
