Thread: Trouble opening in 2010
    2009-07
    124
    Default Trouble opening in 2010
    I'm trying to open a Revit file from the Architect and I'm getting an initial screen that tells me to close Revit and then all hidden windows. Don't I need to have Revit open to close hidden windows? And when I go to view->windows the "close hidden" is ghosted and not clickable.
    Here is the full list of instructions I get when I open the Revit file.
    To properly save, close and exit Revit
    1. Close Hidden Windows
    (go to the VIEW ribbon, select Close Hidden)
    2. Go to COLLABORATE ribbon -> Synchronize with Central
    -> Synchronize and Modify Settings
    3. Click OK
    5. Click the red "X" in the upper right corner of your screen
    The problems I'm having here are
    1. can't close hidden windows
    2. don't see "Synchronize and Modify Settings"
    3. this I can do
    5. I never get a "red X"
    100 Club smcmillin's Avatar
    2006-07
    180
    Default Re: Trouble opening in 2010
    Are you using "Detach from Central" option prior to opening?
    You can't triple stamp a double stamp Lloyd!!!
  1. Trouble opening dwg
    By molivier in forum AutoCAD Map 3D - General
    Last Post: 2011-10-28, 10:13 PM
  2. Trouble opening an invalid DWG
    By lansdell.k805618 in forum AutoCAD General
    Last Post: 2011-04-21, 08:34 AM
  3. Trouble opening files
    By ferriein in forum ACA General
    Last Post: 2010-05-25, 12:21 PM
  4. Other companies having trouble opening my files!
    By jfruscione in forum AutoCAD General
    Last Post: 2007-08-23, 02:59 PM
  5. Trouble Opening Recent Sheet Sets
    By raymond.p.remmers in forum AutoCAD Sheet Set Manager
    Last Post: 2005-02-09, 04:29 PM
