Thread: multiple users in same sheet set?
    2008-05
    58
    Default multiple users in same sheet set?
    is it possible to have multiple people in the same sheet set? Production capacity may dictate a need for this with us. Thanks.
    Houston
    7,520
    Default Re: multiple users in same sheet set?
    Yes.
    All AUGI, all the time TerribleTim's Avatar
    2006-03
    Tacoma, Wa
    627
    The "Sheet Set" is just a central information point. It's just a file that points to all the other files. You can have as many users "reading" that file as you want. They will all see the same thing and be able to access all the same files from it. Also, if a user has a drawing open and another user wants to open that same drawing, the Sheet Set will actually tell you who has it open. That way you can yell at the right person when they should be out of it.
    Tim McDougald
    CAD/BIM Manager / Assistant P.M.
    KMB Design Groups, Inc. P.S.
    828 7th Avenue SE - Olympia, Washington 98501
    HayWire Racing
    1101 124th Street South, Suite B - Tacoma, Washington 98444
  1. Best ideas for multiple users on BIG jobs
    By pauljordan in forum NavisWorks - General
    Last Post: 2011-04-08, 03:44 PM
  2. Multiple users accessing ADT on the same machine
    By tonori in forum ACA General
    Last Post: 2006-03-14, 08:19 AM
  3. Using Layer States between multiple users
    By peterdallyn in forum AutoCAD LT - General
    Last Post: 2006-01-26, 01:19 PM
  4. Multiple Users, same file
    By kstump in forum ACA General
    Last Post: 2005-09-13, 09:07 PM
