sinc
If you use a Description Format that looks like this:
Then you'll get what you want in your Full Description. That code says to "Use everything except for the first parameter." In Desc Keys, "parameters" are space-delimited strings. So if your Raw Desc looks like this:
V-DEC 24
you have two parameters; the first is "V-DEC" and the second is "24". And actually, parameters count up from 0, so "V-DEC" is considered to be Parameter 0, and the "24" is Parameter 1.
A description format like this:
will be replaced with all of the parameters - in effect, it's a pass-through, and says "Use the entire Raw Desc".
You can also grab specific parameters using $0, $1, $2, $3, $4, $5, etc.
So for example, assume we have this Raw Desc:
a b c d e
All other text in the Desc Format gets passed through unchanged. So here's what we'd get for various Desc Formats (first line is the Desc Format, and the second line is the resulting Full Desc):
a b c d e
b c d e
$0
a
$1
b
$2 $3
c d
TREE $*
TREE a b c d e
TREE $+
TREE b c d e
TREE $2
TREE c
$3 TREE $1
d TREE b
