Results 1 to 7 of 7
Thread: text mask deletes text
    2009-05
    Mackay
    18
    Default text mask deletes text
    Sometimes I use the express text mask and the text disappears. This is most frustrating. I'd rather use mtext and background mask but occassionally resort to using text masks.
    Has anyone else had this happen? Or know of a fix? We are using acad 2008.
    Houston
    7,520
    Default Re: text mask deletes text
    Sounds like the wipeout is "on top" of the text. What happens if you use the ._TEXTTOFRONT command?
    2009-05
    Mackay
    18
    No, I turn the wipeouts on select everything in the vicinity and there is no text behind them. They literally vanish.
    In the screen shots, I only masked those few where you can see the wipeouts.
    Houston
    7,520
    Can you post (or email) a sample drawing?
    2009-05
    Mackay
    18
    dwg attached,
    Houston
    7,520
    Yes, I see what you mean.
    I ran an AUDIT on the drawing and it found and fixed 370 errors.
    Now the textmask works OK for me.
    2009-05
    Mackay
    18
    Thumbs up Re: text mask deletes text
    simple fix, brilliant. Thank you very much mate.
    Though I feel like a bit of a dill for not having thought of that
  1. 2011: Text Mask looses text
    By ccook79 in forum AutoCAD General
    Last Post: 2010-11-19, 07:39 PM
  2. TEXT MASK
    By Dianmed in forum AutoCAD General
    Last Post: 2009-05-21, 01:51 PM
  3. Replies: 8
    Last Post: 2007-07-03, 04:25 PM
  4. Updating Text Mask once Text has been edited
    By r_soula in forum AutoCAD General
    Last Post: 2007-06-05, 03:05 AM
  5. Help with Text Mask
    By TimTheriault in forum AutoCAD General
    Last Post: 2005-08-10, 03:12 AM
