Results 1 to 6 of 6
Thread: Spot elevations not tagging properly
    2008-07
    64
    Angry Spot elevations not tagging properly
    I am trying to tag floor elevations in my auditorium but the elevation tag will only tag the edges of the floor slab. Now since it is an auditorium i see the same floors in the mezzanine view- and i have had no problems tagging the elevations of THE SAME FLOORS anywhere on the floor- it does not limit me to the edges. I am using the same spot elevation tag from first to mezzanine. Does anyone know why this would be? Anyone have any ideas on how i can fix it?
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Cool Re: Spot elevations not tagging properly
    Are the floors sloping? if so, are they edited with points, or a slope arrow?
    Try going to a section and see if the spot elev. tool works there?
    Perhaps post an example?
    cheers...
    2008-07
    64
    Default Re: Spot elevations not tagging properly
    It is not sloped. see attached pdfs of the mezzanine that is tagged properly, the section that is tagged properly, and the first floor that is being a butthead!
    2004-05
    St. Louis, Missouri
    3,135
    Wink Re: Spot elevations not tagging properly
    Try creating a Plan Region at one of the lower floor tiers with a custom View Depth,
    and see if you can then apply the spot elevation.
    I suspect it is something with View Range that's causing the problem.
    Also, go to a 3D view and isolate the floor slabs and elevation tags--see if they tag
    in the 3D view?
    cheers........
    Active Member TheViking's Avatar
    2005-03
    Lexington, MA
    88
    Make sure you are not in wireframe. The spot elevation needs a surface or an edge to work.
    2011-10
    2
    Thanks! This helped me just now.
  1. 2015: spot elevations
    By MikeJarosz in forum Revit Architecture - General
    Last Post: 2015-08-14, 04:44 PM
  2. spot elevations
    By bensondl in forum Revit Structure - Wish List
    Last Post: 2007-08-16, 01:05 PM
  3. Spot Elevations
    By kwong in forum Revit Architecture - General
    Last Post: 2007-07-16, 04:24 PM
  4. How to properly crop Interior elevations?
    By jwilhelm in forum Revit Architecture - General
    Last Post: 2004-05-10, 08:44 PM
  5. spot elevations
    By brunelle in forum Revit Architecture - General
    Last Post: 2004-01-16, 04:42 PM
