Thread: Add background mask to dtext
    2009-05
    17
    Default Add background mask to dtext
    Is this possible to add background mask to dtext without using express tools.
    hareeshmb
    2004-08
    Hartford, Michigan
    3,086
    Default Re: Add background mask to dtext
    Quote Originally Posted by hareeshmb.219554 View Post
    hareeshmb
    as far as I know, it is only possible to add a background mask to mtext without express tools, you could also add a wipeout without using express tools, but it wont be linked to the text.
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    AUGI Director scott.wilcox's Avatar
    2001-01
    Edmonton, Alberta
    961
    Lee Ambrosius has a lisp somewhere that does this; let me try and track it down...
    Check this link:
    Why draw straws? Just draw one straw and array it.
    Scott Wilcox - Edmonton, Alberta
    2009-05
    32
    If you are using 2010, (or several versions earlier for that matter) then it is an option in properties to use a background mask. It is called "fill color" in the dimensions. Just set the color to "background."
  1. Background Mask
    By pants in forum AutoCAD General
    Last Post: 2010-10-13, 09:39 PM
  2. Background Mask Defailts
    By bowtle in forum AutoCAD Annotation
    Last Post: 2008-10-09, 12:19 AM
  3. Using BACKGROUND MASK with DWF
    By clarkrj in forum Design Review - General
    Last Post: 2008-01-22, 08:26 PM
  4. Background Mask
    By anton_4u in forum AutoCAD General
    Last Post: 2006-08-30, 06:22 PM
