Results 1 to 10 of 10
Thread: pipe/structure labels with split views
    2003-11
    281
    Default pipe/structure labels with split views
    Is there a known issue with structure labelling in split profile views in C3D 2008?
    I have had a problem in a few drawings now where the stucture profile label command does nothing when you select a structure in a split profile view. If you use the same style on profile view with no splits in the same drawing the label works.
    The other problem is when i label pipes in split views. The labels hold on the first few split views but the remaining dissappear after saving.
    Civil Engineering Moderator civil3Dguide's Avatar
    2006-01
    Temecula, CA
    281
    Default Re: pipe/structure labels with split views
    Are you labeling a single part in profile or entire network in profile?
    The labels do act funny in the split views!
    2003-11
    281
    single part.
    you say they act funny. do you mean just in 2008?
    2006-01
    Temecula, CA
    281
    No not just in 2008, I have not done any split views in 2010, so I'm not sure if it works better in the lastest version or not. I just remember that when I've worked with split views in the past I had some trouble very similar to your problem, labels would disapear at times. I don't recall it being a big or constant problem.
    2001-05
    Austin, TX USA
    2,201
    I've used split views in 09 and 10. Haven't had issues like this.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2008-01
    I am now using Civ3d 2010 and have problems with the pipe "ellipses" showing up in the incorrect spot on the profile view. See attached. The program is putting the ellipses as if the profile view were not split.
    Any suggestions?
    Last edited by jpruispn; 2010-04-09 at 09:54 PM. Reason: png file didnt attach. hopefully pdf will work.
    2006-01
    Temecula, CA
    281
    I'm having trouble seeing the attached!
    2009-03
    I'm having the same issue; 2009 latest SP on Vista and XP. I've recreated the profile view, and it does the same. Please tell me somebody knows of a fix, otherwise I'll have to explode this profile view.
    Jon
    2003-11
    281
    I'm still exploding in profile.
    And now I've decided to turn the display off for my plan pipes and show then with polylines. The reason i do this is because I use pipe centerline with ST, SA, and W linetype but if the pipe isn't flowing with the stationing, then my linestype appear upside down in contract sheets.
    My next project, I'm keeping design and production files separate.
    2005-04
    12
    Quote Originally Posted by randyspear View Post
    I have not had any problems with the pipe elipses showing up but then i write the styles, it does sound like it may be a style setting though.
    as for the centerline of the pipe showing the linetype in the wrong direction an easy way to fix that is to remove the pipe and insert it in the opposite direction if you still want the information to be inteligent.
    most of the issues that people encounter i have found out can usually be easily fixed with a style adjustment.
    hope this helps
  1. Pipe Inverts at Structure Wrong Location on Split Profile
    By dmanning in forum AutoCAD Civil 3D - Pipes
    Last Post: 2008-10-17, 03:36 PM
  2. Pipe inverts in structure labels
    By Ammon in forum AutoCAD Civil 3D - General
    Last Post: 2006-09-26, 04:46 PM
  3. Pipe/Structure Labels
    By MMccall.83699 in forum AutoCAD Civil 3D - General
    Last Post: 2005-08-15, 06:49 PM
