All,
Having a problem where I cannot get the Silent Install to work correctly and honor the MST file.
If I use:
<Software>\Autodesk\NavisWorks_Review_2010\AdminImage\Setup.exe /qb /I <Software>\Autodesk\NavisWorks_Review_2010\AdminImage\Navisworks Review 2010.ini /language en-us
when the original "setup.exe" spawns other installers it terminates, which is very early, it tells the parent app that called the installer, "I'm Done", and it is not, more has yet to be done.
If I use:
<Software>\Autodesk\NavisWorks_Review_2010\AdminImage\x86\NAVREV\roamer.msi TRANSFORM=<Software>\Autodesk\NavisWorks_Review_2010\AdminImage\x86\NAVREV\roamer-Navisworks Review 2010.mst /Lev c:\LOG\Autodesk_Navisworks_Review_2010_32bit.log /norestart /qb /passive ADSK_SETUP_EXE=True
it does not honor the transform from the administrative install, so the required preset license info is not included...
Any ideas?
Does anyone know if the 2011 versions are InstallShield "Setup" based or true MSI's?
Thanks for any and all help in resolving this problem.
John
