cliff collins
You can select the "nested" detail component in the window family and specify the
level of detail it will display at--Coarse, Medium, Fine, etc. We usually set it to display at Medium and Fine only.
Then load into your project.
In your RCP, set detail level to Coarse to "hide" the detail component.
If you need it to show up in enlarged ceiling plans/details, set detail level to Fine.
It may also be possible to add a new visibility parameter for Visibility set to On/Off
or Yes/No, share the nested family, load into project and have even more control over
the detail component's visibility. ( I have not tested this exact situation. )
cheers.........
