Thread: Converting Revit splines to AutoCAD splines
    2008-12
    44
    Default Converting Revit splines to AutoCAD splines
    Hi,
    I recently converted a 3D form based on a spline from Revit 2009 to AutoCAD so someone using AutoCAD could use it.
    However, the curve of the spline became dramatically altered during the conversion.
    Have others encountered this problem, and is there a work-around? I've been searching the threads and it sounds like most of the issues have been centered around converting from the other direction.
    The attached files illustrate the problem.
    Derek
    I could stop if I wanted to William Troeak's Avatar
    2005-12
    standing @ the crossroads
    240
    Default Re: Converting Revit splines to AutoCAD splines
    Try selecting the spline in Revit and add CONTROL POINTS to the spline from the EDIT SPLINE PANEL in the CONTEXTUAL TAB.
    You may need to add a few control points to get Autocad to read the spline the same as Revit............
    William Troeak
    Technical Specialist, Architecture
    US CAD
    Revit Architecture/BIM Instructor
    Long Beach City College
    2008-12
    44
    Thank you, appreciated!
  1. 3d Splines into Revit Structures
    By duncan.cox426162 in forum Revit Structure - General
    Last Post: 2011-11-15, 03:42 PM
  2. Revit Splines Are A Joke
    By Limbatus in forum Revit Architecture - General
    Last Post: 2011-06-27, 06:00 PM
  3. Splines
    By sarahh62907188 in forum Revit Architecture - Families
    Last Post: 2011-05-05, 07:46 AM
  4. Converting splines to polylines?
    By matt.143284 in forum AutoCAD LT - General
    Last Post: 2007-08-31, 12:47 AM
  5. Splines
    By dduarte in forum Revit Architecture - General
    Last Post: 2006-04-21, 09:11 PM
