Thread: Audit/Purge - Local/Central File
    2008-02
    95
    Default Audit/Purge - Local/Central File
    In the event that the Audit or Purge option needs to be performed in Revit, should they be done while in a local file or should you open the central and do it?
    If you purge from the Central file do those who have a local file need to create a new local file?
    Thank You
    Certifiable AUGI Addict cliff collins's Avatar
    2003-09
    St. Louis, Missouri
    3,071
    Cool Re: Audit/Purge - Local/Central File
    1. First--check with everyone on the team before purging.
    2. Once you have approval, open the Central and click Audit. Note file size.
    3. After it opens, go to Manage>Purge Unused and Purge.
    4. Then Synchronize to Central, and compact.
    5. Close Revit and then Open the Central file again, note file size difference.
    Click Create New Local.
    6. Then have all team members follow step 5.
    cheers.......
    Cliff B. Collins, Registered Architect / BIM Specialist
    St. Louis, MO
    2008-11
    73
    Default Re: Audit/Purge - Local/Central File
    You'll also want to verify that you've relinquished all your worksets. Detaching from Central file will check them all out to you.
  1. 2012: Local file synch to Central file on temporary server
    By amradcliff in forum Revit Architecture - General
    Last Post: 2012-03-29, 11:22 AM
  2. Local File Incompatible with Central File - Revit 2010 Error??
    By ekneer in forum Revit Structure - General
    Last Post: 2010-02-18, 02:51 PM
  3. Cannot Purge or Audit File
    By kmarquis in forum Revit Architecture - General
    Last Post: 2010-02-09, 03:29 PM
  4. Use audit on local or central?
    By Wes Macaulay in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2007-06-21, 04:04 PM
  5. How do I save Local Client file to become Central file?
    By Richard McCarthy in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2004-03-29, 05:44 AM
