I have a OS Windows 7 64 bit PC with MAP 3D 2010 (64x) and CIVIL 3D 2010 (32x) installed on it.
On Map 3D 2010 (64x) SP1, I have installed the VBA Manager Enabeler (extra to be dlled)
When I start Autocad (Map or Civil) I load the following acad.dvb from the same folder
Sub AcadStartup()
AcadApplication_Events
LoadDVB "D:\acad2kx\custom\vba\PDFArchive.dvb"
Exit sub
CIVIL 3D 2010 32x opens normal without problem.
MAP 3D 2010 64x opens with an error:
Display Driver file (.hdi) is missing or has been corrupted
This problem may be caused by missing .hdi files in the following location:
C:\program Files (x86)\AutoCA Civil 3D 2010\Drv\
(I have no error if Civil 3D is started before I start Map 3D)
This error occurs not only on the first action: AcadApplication_Events
but also on if the first function should be: LoadDVB "D:\acad2kx\custom\vba\PDFArchive.dvb"
I have no error if I modify the AcadStartup into
Sub AcadStartup()
MsgBox "test"
Exit sub
Does anyone has the same problem?
Which Driver should be missing?
