Results 1 to 10 of 17
Thread: ObjectARX Enabler
    Active Member h.jobe's Avatar
    2005-11
    Turlock, CA
    97
    Default ObjectARX Enabler
    How do you know which type of enabler you need to install in order to see the appropriate proxy graphics?
    I should note that I know which proxy is causing the problem - it shows up as a rectangle with an "x" through it. I just don't know which program created it.
    2000-01
    Seattle WA USA
    5,859
    Default Re: ObjectARX Enabler
    That's a good question. I presume you cannot ask the original author of the drawing? If not, can you post the drawing with nothing but the proxy object(s)?
    P.S. Are you related to Ed?
    R. Robert Bell
    Design Technology Manager
    Stantec
    2005-11
    Turlock, CA
    97
    Hit me with your best shot.
    And, yes, I'm his daughter.
    Earth
    9,804
    Is your PROXYNOTICE set to 1?
    My guess would be Architectural Desktop, but I'm not too familiar with its application names, so that may not be it. I'm sure someone will come along to confirm or correct.
    R.K. McSwain | CAD Panacea |
    2000-01
    Seattle WA USA
    5,859
    That was pretty easy... it is RText which is an Express Tool. Get Ed to install Express Tools on your computer (and tell him "hi" from Bob Bell!).
    R. Robert Bell
    Stantec
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by RobertB View Post
    Although... why anybody is actively using RText now is beyond me... aside from the XRefs feature (why Fields doesn't have that yet is also beyond me.)
    R. Robert Bell
    Stantec
    Earth
    9,804
    That was pretty easy....
    Talking to yourself again huh...?
    Back to the topic, I didn't get the proxy notice about the RTEXT since mine was loaded and it didn't occur to me that this was RTEXT, for reasons you mentioned above...
    2005-11
    Turlock, CA
    97
    Well, the express tools solved one problem - thanks for that.
    However, it appears that I have another proxy hiding in the drawing that I can't find. The proxy info that pops up when I open the drawing tells me that the missing application is aecbbldsrv40. There's not a lot of info to be found by doing a simple search about this particular application. Aec is usually an autocad architecture prefix, am I correct?
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by h.jobe View Post
    You need to install the object enablers for both Architectural and then MEP. You need to install Arch first, then MEP.
    AecbBldSrv40 is part of the MEP vertical which is based on the Architectural vertical.
    However, you need to be running a version of AutoCAD that matches or exceeds the version of the original MEP file (4.0 is pretty old, 5.5 is 2008's version). MEP objects are usually upgraded each release and are not downwards compatible, despite the 3-year cycle for DWG formats.
    R. Robert Bell
    Stantec
    2000-01
    Seattle WA USA
    5,859
    Um... yes. (No! Bob, don't answer that!) Shut up!
    R. Robert Bell
    Stantec
  1. Where is ObjectArx from Autodesk?
    By Dan.Anderson in forum AutoCAD Customization
    Last Post: 2011-12-07, 10:25 PM
  2. ObjectARX
    By Ehsan in forum Dot Net API
    Last Post: 2011-09-07, 10:15 PM
  3. about ObjectARX
    By mdsalman2003 in forum ARX
    Last Post: 2010-06-11, 12:22 PM
  4. Autolisp, ObjectArx, Vba
    By alanferreira.l in forum AutoLISP
    Last Post: 2010-02-15, 10:23 AM
  5. AEC Enabler
    By cadman6735 in forum ACA General
    Last Post: 2009-09-11, 03:00 AM
