Results 1 to 6 of 6
Thread: Center Lines in Beam Family - when beam is cut
    2008-07
    Brisbane (Ex. Swedish)
    349
    Default Center Lines in Beam Family - when beam is cut
    Hi,
    We usually show the centroids of our rafter in section ie the centre lines (see attached image). I have tried to add these to a beam family but not with much success.
    If I add symbolic lines for Left/Right Reference plane they only show up when beam is horizontal which make sense as symbolic lines has to be perpendicular to the view plane.
    The only way I can think of to get this to work is to add Model Lines to Member Left AND Right Reference Planes and make sure the visibility is set to Left/Right. This will make sure that the lines show up in the elevations etc.
    I can then also add the symbolic Lines as above to be able to see them when I cut a beam that is perp. to the view plane.
    At the moment I use a detail component that I go though and to all my beams in my views – which takes for ever.........
    J
    2007-03
    147
    Default Re: Center Lines in Beam Family - when beam is cut
    Quote Originally Posted by JH75 View Post
    J
    What do you mean by this? Are you superimposing a detail component on your model?
    You can control the center line visibility when the steel section is cut.
    2008-07
    349
    Hi,
    Yes we add the detail component with the centre lines to all beams that are cut. The detail componet only contains the 2 lines and we can adjust it to suit the member width & hight.
    How can I control the visibility of the member centre line?
    Thanks
    J
    2007-03
    147
    Hi,
    J
    You draw the center lines using Detail>Symbolic Line in Left Elevation while choosing work plane reference plane: Center (Left/Right). Afterwards, select the lines you just drew and under the Instance Properties>Identity Data>Subcategory, choose “Structural Framing [cut]”. Finally select under Graphics Visibility/Graphics Overrides>Edit>, you open the option “Family element visibility settings”, set “Show only if instance is cut” to ON (tick mark).
    I hope that my advice helps you. You can now get rid of your 2D component lines.
    Cheers,
    2008-07
    349
    I have tried that but it will not work if the beam/rafter is on a rake/sloping as symbolic lines only show up when they are perpendicular to the view plane.
    Cheers,
    J
    2007-03
    147
    I have tried that but it will not work if the beam/rafter is on a rake/sloping as symbolic lines only show up when they are perpendicular to the view plane.J
    I guess you must use a Grid.
  1. Legends - how to show beam-beam & beam-col conn?
    By lcamara in forum Revit Structure - General
    Last Post: 2014-05-04, 10:45 PM
  2. Create a new beam system justification that is "Center Space"
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2013-03-04, 09:24 PM
  3. Replies: 1
    Last Post: 2010-08-30, 05:46 AM
  4. Beam and wall center line
    By Galadriel in forum Revit Structure - General
    Last Post: 2010-08-10, 07:36 PM
  5. Concrete beam with sloped top + Beam family question...
    By scowsert in forum Revit Structure - General
    Last Post: 2007-12-22, 03:36 AM
