Thread: Can not Edit Room Style Column in Room Schedule
    2003-08
    Tijuana
    225
    Default Can not Edit Room Style Column in Room Schedule
    I can't change the values of the room style column in my room schedule. When I click on a cell on this column the arrow of the drop down selector doesn't appear. Any ideas?
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: Can not Edit Room Style Column in Room Schedule
    A room style is pulled from a schedule key. You only edit the schedule key. So my guess is you have no styles defined.
    Scott D. Brown, AIA
    BECK
    2003-08
    Tijuana
    225
    Thanks for the reply Scott.
    The problem persists, and there are styles defined. We have a door schedule that pulls from a door style schedule key without problems, but the room schedule just won't work. The workarround to that was to select the room objects and change values through object properties.
    2003-05
    Coast to Coast
    4,440
    Is it in a group? You would need to have group editable to edit the room info. this is one reason I don't include rooms in groups.
    Scott D. Brown, AIA
    BECK
    2006-05
    6
    I'm having the same issue. I can make the key styles populate the room schedule by assigning them to the room directly but I cannot access the drop down arrow from the room schedule. The rooms are not part of groups either. Does anyone know why this is occurring?
  1. 2015: Door Schedule not populating To Room and From Room
    By gross695874 in forum Revit Architecture - Families
    Last Post: 2015-03-26, 05:44 PM
  2. 2015: Using Room Separtors and Room Schedule Showing Area Not Placed
    By Thayana in forum Revit Architecture - General
    Last Post: 2014-11-12, 07:38 AM
  3. Door Schedule - To/From Room Minimum Room Size
    By Michael Coviello in forum Revit Architecture - General
    Last Post: 2009-04-23, 02:18 PM
  4. Shared Parameters to show in Room Style Schedule
    By cstarr in forum Revit Architecture - General
    Last Post: 2006-05-27, 12:42 AM
  5. Quick Room Finish Schedule by Room Type
    By SCShell in forum Revit Architecture - Tips & Tricks
    Last Post: 2005-11-08, 02:21 AM
