Results 1 to 10 of 10
Thread: Newbie Q: Is there a two-line trim/extend?
    2010-01
    26
    Default Newbie Q: Is there a two-line trim/extend?
    I find when doing architecture drawings there's often a need to trim/extend two lines to form a corner. I found the TRIM command, which is very efficient for some situations, but is a bit tedious for simply trimming two lines to make a corner. E.g., with other cad programs, it's select tool, pick, pick, and you're done. TRIM requires several more steps. Is there simple two-line trim for autocad?
    I could stop if I wanted to Mamma Jamma's Avatar
    Massachusetts
    336
    Default Re: Newbie Q: Is there a two-line trim/extend?
    fillet, with a radius of 0
    Mamma Jamma
    "Normal is an illusion. What is normal for the spider is chaos for the fly"
    Morticia Addams
    Massachusetts
    336
    or chamfer, with the distances set at 0. (both the fillet and chamfer settings will be retained for the next time)
    Also you can reverse the trim command to extend, simply by holding down the "shift" key.
    And if you hit enter rather than selecting an object, both trim and extend will then trim and extend to the next nearest object.
    Mamma Jamma
    Morticia Addams
    2002-09
    Madison, WI
    4,440
    You can still you the "fence" command with trim if you need to do multiples.
    enter the trim command as you normally would and hit "f" for fence.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    2010-01
    26
    Cool. Thanks Mamma! I tried all your suggestions and they worked great.
    Followup question -- When using FILLET or CHAMFER, the command quits after picking two lines. Is there a way to keep it "in" the command until I tell it to stop?
    2002-09
    Madison, WI
    4,440
    I believe you can choose 'M' for multiple after you start the command and before you pick, sim to the copy command.
    Dave Peterson
    2010-01
    26
    Quote Originally Posted by david_peterson View Post
    Yes! Thanks!!
    2003-10
    688
    Quote Originally Posted by buttonsrtoys View Post
    Do what I do. Keep your finger on the space bar (as opposed to the ENTER button) and when you fillet the first one just hit SPACE to pop ya right back in the command. I know it seems like you're doing more by hitting the space bar every time but you don't have to "do something" to get you into the multiple feature of the command and you don't have to "do something" to get you out of the command.
    Just a personal way of doing it. Multiple works too.
    2007-07
    Jo'burg SA
    4,344
    Or try my multiple fillet command in this thread: http://forums.augi.com/showthread.ph...illet+multiple
    I use it quite often to create corners for multiple lined walls. For just the 2 lines it's not that much quicker, but for cavity / composite walls it rules!
  1. Trim/Extend everywhere
    By notuition1966 in forum AutoCAD Tips & Tricks
    Last Post: 2009-09-04, 07:58 PM
  2. Trim or extend line to line - dynamic block
    By janandraczko in forum Dynamic Blocks - Technical
    Last Post: 2009-03-01, 11:33 PM
  3. trim/extend
    By kwanjuju in forum AMEP General
    Last Post: 2008-03-17, 06:57 PM
  4. trim and extend
    By billynutts in forum ACA General
    Last Post: 2008-01-21, 01:54 PM
