Thread: Annotative block moving when changing scale
    2008-10
    London, UK
    103
    Default Annotative block moving when changing scale
    Hi all, I've having a small problem with an annotative block I have created.
    When I change the annotative scale in model space a couple of things happen.
    Firstly the block doesn't seem to be attached to its insertion point and jumps arouns a bit.
    Secondly the text I have in the block moves away from the block as well.
    I have attached a selection of screen prints with the block at different annotation scales so you can see (albeit slightly small) the movement of the block.
    I have also attached the block itself.
    Many thanks in advance for any help with sorting out this problem.
    Jon.
    2008-10
    London, UK
    103
    Default Re: Annotative block moving when changing scale
    Ok, scrub that, I had annotative text in the block and that seems to be screwing it up.
    I've recreated the block and just used standard text and that seems to be working properly through all the scales.
    2008-10
    London, UK
    103
    Bah...my joy was shortlived.
    Still seems to be jumping around and not attached to its insertion point. The text seems to be staying in place now though. Also it isn't happening on as many diferent scales.
    Most confusing.
    Please help!
    2012-02
    14
    Question Re: Annotative block moving when changing scale
    Quote Originally Posted by jonathan.a.pitt View Post
    Most confusing.
    Please help!
    I have the same issue!
    My annotative block that contains an attribute is moved automatically as the annotation scale changes!
    What might be the issue here?
    Best
    Jamal
    2015-10
    158
    Is the insertion point (0,0,0 in the block editor) "away" from the block geometry? If so, distance from entities to insertion point will scale up with the scale.
  1. 2014: Scale elements inside a non annotative block using a formula
    By jpcadconsulting347236 in forum Dynamic Blocks - Technical
    Last Post: 2014-01-21, 05:05 PM
  2. Dynamic Block keeps "moving" when Annotative scale is changed
    By e3do in forum Dynamic Blocks - Technical
    Last Post: 2011-10-18, 08:03 PM
  3. Moving multileader when changing scale.
    By Jonathan Pitt in forum AutoCAD Annotation
    Last Post: 2010-06-04, 01:47 PM
  4. Huge lag after changing VP Annotative scale
    By Bryan Thatcher in forum AutoCAD General
    Last Post: 2009-03-01, 08:29 PM
