Thread: Extrude on Ellipse Path
    100 Club lswinea's Avatar
    Arlington, Texas
    174
    Default Extrude on Ellipse Path
    Trying to create a 3d model using a profile that I want to extrude on an ellipitical path.
    I have attached as an example.
    I use mechanical, but only open the vanilla part. 2010
    0,0,0 The Origin
    8,026
    Default Re: Extrude on Ellipse Path
    I don't think acad can handle the proportions of the section versus the small rads of the ellipse.
    I can make it just slightly large but the section reverses so that the narrow end is outward and I can make it about right if I cut off the ends of the ellipse. (All done using the largest ellipse and the outermost section.)
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
  1. Extrude to Path not working???
    By larrytech10 in forum AutoCAD 3D (2007 and above)
    Last Post: 2010-03-29, 01:40 PM
  2. extrude along a path
    By tomcarver in forum AutoCAD 3D (2006 or below)
    Last Post: 2008-02-01, 10:34 PM
  3. AutoCAD 2006 extrude along a path - Profile and path are tangential.
    By judekw in forum AutoCAD 3D (2006 or below)
    Last Post: 2007-05-24, 07:48 PM
  4. sweep along ellipse path error.
    By sbrown in forum Revit Architecture - General
    Last Post: 2004-09-02, 02:19 PM
