Results 1 to 6 of 6
Thread: Exporting to Polygon shape files
    2006-11
    2
    Default Exporting to Polygon shape files
    I get the message "0 objects of 9 selected, exported in 1second" when I try to export Acad polygons to a Shape file. I am using ACAD 2010 Map 3D. Any Ideas?
    South Eastern US, exact location unknown
    1,369
    Default Re: Exporting to Polygon shape files
    Are you selecting polygon as the type to export in the object type if so they have to be mpolygons otherwise set the object type as line and/or check the box to "Treat closed polylines as polygons" on the option tab.
    J. Murphy
    AKA
    Murph
    The former AutoCAD MAP3D Power User
    2006-11
    2
    Quote Originally Posted by Jmurphy View Post
    You're the MAN. I was selecting polygons as the type. However they are just polylines closed to form polygons. I don't even know what a mpolygon is. Obviously I'm new to all of this.
    THX a bunch for your help!!!!!!!!!!!!
    2005-12
    90
    You can not also export objects on locked layers.
    Houston
    7,519
    Exclamation Re: Exporting to Polygon shape files
    As bamagnuson said (and I already knew....) --- you are the MAN.
    I was just doing the same thing and knew there was a trick to it.
    Thanks.
    1,369
    Thanks.
    I guess its good to keep the old man around for a while then.
    J. Murphy
    AKA
    Murph
  1. RE: SHAPE FILES 2008 -- WTF???
    By CADTigress in forum AutoCAD General
    Last Post: 2008-01-04, 06:47 PM
  2. Missing Shape Files / Select Shape File
    By Mac Demer in forum AutoCAD General
    Last Post: 2006-11-05, 12:36 PM
  3. Polygon topology exports extra records to shape file
    By jim.dahl in forum AutoCAD Map 3D - General
    Last Post: 2006-05-09, 09:17 PM
  4. Using Mr. Sid Shape files in Map
    By jmckinney.91816 in forum AutoCAD Map 3D - General
    Last Post: 2005-10-13, 08:22 PM
