Thread: Text Problem
    2009-02
    Newcastle N.S.W. Australia
    36
    Default Text Problem
    I have two drawings open in the one autocad session. Both have the same text style, one displays text symbols e.g. dia, degree etc OK the other just shows a "?" instead of the symbol.
    please help someone
    2007-07
    Jo'burg SA
    4,348
    Default Re: Text Problem
    Not if the text styles are exactly equal. Remember ACad's Text Style is not the same as a font. Type the style command and see how the 2 DWG's styles differ.
    If you want ACad to check this automatically, saveas the correct DWG as a DWS file. Then in the incorrect DWG start the standards checker (Tools --> CAD Standards --> Configure...). Click the plus button & browse to the DWS you saved & click Open. Back in the Configure Standards, open the Plug-Ins tab and ensure only the Text Styles plugin is selected (otherwise you'll get all other differences). Click OK. Then start the checker (Tools --> CAD Standards --> Check...). It should show you each difference in the text styles (per style).
    I'd think the most obvious possibility would be that you're using the \U+00D8 instead of %%C. Some fonts may not have the Ø (Latin Capital Letter O With Stroke), especially SHX fonts.
  1. problem with text box
    By jomzcruz in forum AutoLISP
    Last Post: 2010-08-12, 09:03 AM
  2. Problem Text
    By tsmethurst in forum AutoCAD General
    Last Post: 2010-02-26, 01:11 AM
  3. OLE text problem
    By wsittner in forum AutoCAD LT - General
    Last Post: 2009-05-01, 03:31 PM
  4. Text Problem
    By jbayne in forum ACA General
    Last Post: 2006-09-14, 12:55 PM
  5. Text Problem
    By Scott_Bloss in forum Revit Architecture - General
    Last Post: 2004-10-15, 11:38 AM
