Thread: inventor to revit
    2007-07
    12
    Default inventor to revit
    I need to get inventor equipment into Revit MEP. If i understand correctly, aec exchange (.adsk export) became available in inventor 2010. Our supplier still works in Inventor 2009. Is there any way to get the equipment converted without me having to buy inventor? are there any converters out there ?
    Note to autodesk: could you please add conversion features in your Inventor View?
    P.S. i did order a trial dvd from autodesk, but it takes 3 weeks to ship to Canada o.O
    Manufacturing Moderator jonathan.landeros's Avatar
    2005-03
    Los Angeles County, Ca.
    440
    Default Re: inventor to revit
    Aside from AEC Exchange, the next file to try would be an ACIS or *.sat file. This shouldwork for 2009
    The files tend to be 'heavy' for Revit, since they bring in a lot of extra details that the Revit user typically doesn't need. If the component you're working with is an assembly, then you may want to remove any unnecessary parts before you export (like small bolts).
    Good luck!
    Jonathan Landeros
    KETIV Technologies
    Orange County, California.
    I've got a blog: www.inventor-tales.blogspot.com
    “We have now left Reason and Sanity Junction.Next stop, Looneyville.” -Bob the Skull in the Dresden Files
    2005-06
    in the upper right corner
    3,507
    Quote Originally Posted by jonathan.landeros View Post
    Good luck!
    Thanks for this tip, it helped me allot.
    I am in a similar situation where we have this humongous STEP file of piping and mechanical equipment that was created with SolidWorks (I believe)...
    It started out at 143.000+ KB STEP file, I opened and saved it with Inventor and became a 530 KB assembly, but all the sub assemblies were put into a default Inventor folder.
    So now I have to edit/delete everything we don't need and export it out to a .SAT file for REVIT.
  1. 2013: 3d Revit to Inventor
    By clovis in forum Revit - Plotting/Printing/Exporting
    Last Post: 2013-04-25, 10:08 PM
  2. 2011: Revit - Inventor: on avance!!
    By jbenoit44 in forum Revit Architecture - General
    Last Post: 2010-11-23, 01:21 PM
  3. Revit + Inventor
    By t1.shep in forum Revit Architecture - General
    Last Post: 2009-09-02, 11:58 PM
  4. Revit to Inventor
    By york in forum Inventor - General
    Last Post: 2009-08-03, 03:06 AM
  5. Revit to Inventor
    Last Post: 2009-07-31, 05:33 PM
