Thread: object field values scales with VP?
    2003-11
    285
    Default object field values scales with VP?
    I have a block with 2 fields in it that call up a 2 lengths. they display correctly in model space but in the viewport they are multiplied by the viewport scale.
    Short of exploding all these fields, how can i fix this?
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: object field values scales with VP?
    did you make them annotative?
    S&D DB Sharing Forum
    2003-11
    285
    no, neither the attributes or the objects are annotative.
    I should clarify as well, only the field's values are scaling. the actual block is the right size.
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Could you post a sample?
  1. Default field values
    By junkdiver in forum AutoCAD Fields
    Last Post: 2017-02-17, 01:06 PM
  2. Highlight field for multiple varying values
    Last Post: 2014-11-13, 05:22 PM
  3. 2013: Multiply Schedule field values
    By Spork in forum Revit Architecture - General
    Last Post: 2013-04-09, 01:05 PM
  4. Field Values in Xref not Displaying Correctly
    By sifuentes in forum AutoCAD Fields
    Last Post: 2010-04-08, 03:22 PM
  5. Replies: 3
    Last Post: 2007-03-27, 06:13 AM
