Thread: Plotting light lines and text using PDF
    100 Club dmingo's Avatar
    2006-05
    The original Hockeyville
    115
    Default Plotting light lines and text using PDF
    Hi,
    I plotted a layout to PDF using "DWG to PDF". Looks fine on the PDF, but plots light to the printer or plotter.
    I ran the same thing through a separate computer with AutoCAD Map3D and got the same results.
    Using:
    AutoCAD Map3D 2016
    O/S('s):
    Windows 7 Pro (1st), has Adobe Pro
    Windows 10 (2nd) doesn't have Adobe Pro
    I also noticed that the plot style table has 2 columns (Normal & Style1), instead of the 256 colours that I am used to seeing.
    Any ideas?
    in the upper right corner
    3,508
    Default Re: Plotting light lines and text using PDF
    Quote Originally Posted by dmingo View Post
    Hi,
    Using:
    AutoCAD Map3D 2016
    O/S('s):
    Any ideas?
    Sounds like you're using a different Plot Style (STB vs CTB)?
    When you go to plot, what plot style are you using? someone would have had to change it.
    If it's wrong/not to your standard you need to change it back.
    Look into "Convertpstyles"
    2006-05
    115
    Thanks Ted.
    That didn't do it. I have had this happen on 2 separate drawings. One is a details drawing that I have been using repeatedly, the other a surveyor's drawing produced from other software that I have modified and placed a aerial photo and a polyline on it.
    The first one, the title block and border, and the detail labels come out black - the line work, notes, dimensions, etc. come out faded.
    The surveyor's drawing - the aerial photo and polyline comes out solid, but the other info faded.
    The thing is, it looks fine on the PDF, but when I print it, fade happens.
  1. Family/Symbol plotting too light
    By chasen_forever in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-12-03, 05:23 PM
  2. Plotting too light
    By katysue in forum Revit - Platform
    Last Post: 2008-10-01, 03:00 AM
  3. Lineweights plotting light
    By rstiles in forum AutoCAD General
    Last Post: 2005-06-16, 01:14 PM
  4. Thin Lines? Light Lines? What's it all about?
    By Scott Hopkins in forum Revit Architecture - General
    Last Post: 2005-03-15, 09:58 PM
  5. Color lines are plotting lighter than black lines..
    By akall in forum AutoCAD Plotting
    Last Post: 2005-02-04, 09:28 PM
