Thread: Revision Cloud and Tag
    2008-02
    95
    Default Revision Cloud and Tag
    Under the "Sheet Issue/Revisions" dialog box, is their a way to manaully control the sequence?
    My reason for asking is, when we place a tag on the revision cloud and change from ADD 1 to CCD1 the number of the tag changes to 3. The number value appears to be pulling from Sheet Issue/Revisions. Since we have CCD1 as number 3 in the list, the tag is populated with the number 3 when essentially it is CCD 1 not 3. Is their a way to control this while still utilizing the Sheet Issue/Revisions dialog?
    Pittsburgh, PA USA
    1,906
    Default Re: Revision Cloud and Tag
    You could make the CCD1 issue a Letter instead of a number. You could aldo delete, or possible combine the previous revisions so that CCD become 1
  1. Revision Cloud
    By jonblaze451 in forum Revit Architecture - General
    Last Post: 2012-04-28, 08:08 PM
  2. Revision Cloud
    By rhayes.99001 in forum ACA General
    Last Post: 2010-06-21, 04:56 PM
  3. Revision Cloud
    By johnthao714 in forum Revit Structure - General
    Last Post: 2010-04-09, 08:17 PM
  4. Revision cloud properties in cloud sketch
    Last Post: 2009-02-01, 07:08 PM
  5. Revision Cloud
    By ljones.27809 in forum AutoCAD General
    Last Post: 2005-09-01, 06:35 PM
