I have a number of section views set up and in some 2 of the section views the Levels are not showing up. I see no difference in the view properties or the level properties of those showing up vs those not showing up, im stuck...
In 7.0, you can draw the levels so that they do not intersect the section crop box, in which case, they do not show in the section.
Expand the section crop box to check , or go to a view where the levels are visible and drag the ends to align and lock with other levels.
Its also possible that the levels could be hidden use "hide annotation in view", bit I doubt that in this case.
Beegee, I am not clear on what you are asking me to do , could you clarify a bit? the same issue seems to be afecting my grids, some show up & some dont...
Maybe this image will help ?
In this case you would need to drag the ends of levels 2 and 3 to intersect the section box . They will then display in that section view.
Thanks Beegee
