Thread: Inserting blocks and pesky shape file prompts
    I could stop if I wanted to jgratton's Avatar
    2002-07
    Calgary, Canada
    397
    Angry Inserting blocks and pesky shape file prompts
    The strangest thing...I made several wblocks, each containing one dimension with the text override values different. When I insert them off my tool palette one prompts for a number of shx substitutions and one does not. I ran system variable comparisons on the wblocks and they are identical except for insertion points.
    How can text shx substitutions get caught in dimension text? It does not make sense to me.
    I doubt anyone can help, but it sure feels good to vent!
    Cairo - no, not Illinois
    5,069
    Default Re: Inserting blocks and pesky shape file prompts
    Open the dwg file that is the block, and PURGE it. most likely there are unused definitions hanging loose in the dwg
  1. Redefine Contained Blocks when Inserting a DWG file
    Last Post: 2013-03-20, 08:46 PM
  2. Blocks from Shape file data
    By scott.douglas.smith in forum AutoCAD Map 3D - General
    Last Post: 2011-03-01, 04:13 PM
  3. Keywords in prompts for Block Attribute Prompts.
    Last Post: 2009-01-13, 04:21 PM
  4. Script file not always inserting blocks at same location
    By drafting.82475 in forum AutoCAD Customization
    Last Post: 2008-09-04, 08:09 AM
  5. Missing Shape Files / Select Shape File
    By Mac Demer in forum AutoCAD General
    Last Post: 2006-11-05, 01:36 PM
