Results 1 to 6 of 6
Thread: Ceiling Height Tags
    2009-08
    35
    Default Ceiling Height Tags
    I was just wondering if there was an easy way to tag a ceiling height. Right now our lower level just has text and we would much rather have something that can link the actual height with the tag.
    2004-01
    Columbus OH
    465
    Default Re: Ceiling Height Tags
    Here is something I put together real quick with Labels to read ceiling Type (material) and Height above Level. It should get you started towards what you want to do.
    2006-03
    461
    I can't remember for sure but the default ceiling tag should have another type that is the tag plus ceiling height. If not, there should be one in your annotations in the library.
    2009-12
    23
    If you talking about on the reflected ceiling plan then there are tags that have ceiling heights built in. If you talking about on a floor plan keep reading.
    As far as I know since in plan the room can't read information about a ceiling, which makes sense in rooms with complex ceilings, you have to make the room tag come with ceiling info parameters and then in your model manually input the info into the tag.
    I've attached the room tag we use. The type thats includes ceiling info, once placed in a room, needs to be double clicked and the ceiling type and height can then be entered.
    I don't know if this is exactly what you need but I had this same question last year and was told to do it this way.
    2016-04
    Hi Eric-
    So I just loaded this and then edited it based on our standards, but now I am not sure where it lives in revit. Can you help me out? Thanks!
    2002-09
    Madison, WI
    5,482
    Should be in the annotation items.
    Dave Peterson
    BIM Coordinator
    Acad - 2016 - Revit 2018 w/ A360 - Navisworks - 3ds 2018 - Ensacpe - Lumion - Win 7 64 - i7-6700K 4.0GHz 32GB DDR4 Ram - Nvidia Quadro K2200
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
  1. 'Ceiling' Height Tag
    By antman in forum Revit Architecture - General
    Last Post: 2012-11-19, 06:58 PM
  2. Ceiling tags on slab - no ceiling??
    By pshupe.159931 in forum Revit Architecture - General
    Last Post: 2009-12-22, 11:21 PM
  3. Ceiling Height Tags
    By KGC in forum Revit Architecture - General
    Last Post: 2008-01-30, 05:42 PM
  4. ceiling tags using different level to report height
    By JONB.102117 in forum Revit Architecture - General
    Last Post: 2007-09-21, 05:47 PM
  5. Ceiling Height Tags
    By jesus.plata in forum Revit Architecture - General
    Last Post: 2007-03-29, 10:33 PM
