Thread: Can not export layers on 3D DWF or DWFX...
    2006-10
    25
    Default Can not export layers on 3D DWF or DWFX...
    Hi Everyone, (I'm running Civil 3D 2010)
    I'm putting together a building model for the company I'm working for. I have developed a model with differecnt elements of the building solids on different layers. Example: walls on a layer, columns on a layer, slabs on a layer, etc... When I export to 3D DWF using Civil 3D, I lose the layer names and only get the generic model sub-part names... Solid (3d) [c172f].
    I am able to export the layers using Map 2010. does anyone know why?
    2001-02
    Charlotte
    89
    Default Re: Can not export layers on 3D DWF or DWFX...
    Look under 3d Dwf options....see attached file.
    I think this is what you are looking for
    2006-10
    25
    Talking Re: Can not export layers on 3D DWF or DWFX...
    It was in a different place and looked totally different but I found it.
    Thanks for the help!
    Active Member fkellogg's Avatar
    2005-09
    Virginia, via Fayetteville, Arkansas
    92
    bb, or anyone else
    I see it has been a while since you posted and answer to eraska, that seems to have worked for him.
    I am having the same issue, using vanilla AutoCAD 2019. I have tried everything I can to get Layer info to come through, without success.
    As eraska said, the Solids info comes through.
    I have a 3D desk, with all the "guts" on separate layers, and would like for the viewer to drill down into the guts by turning off layers.
    Multiple attempts vields "None Available" in the Layers Tab.
  1. 2012: Print File (dwfx, pdf) layers & xrefs
    By StDoodle in forum AutoCAD Plotting
    Last Post: 2013-02-14, 04:01 PM
  2. PrintParameters for DWF / DWFx Export
    By msiebert in forum Revit - API
    Last Post: 2010-07-29, 06:18 AM
  3. Setting export defaut to DWF instead of DWFx
    By Mitch Mermel in forum Revit - Plotting/Printing/Exporting
    Last Post: 2010-07-19, 09:22 PM
  4. DWF or DWFx Export in 2010 a bug?
    By Silleke in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-09-28, 11:12 AM
  5. Revit Export to dwf / dwfx 2010
    By trombe in forum Revit Architecture - General
    Last Post: 2009-09-01, 08:34 AM
