Thread: Alignment Table = Sta: Northing Easting
    2005-11
    North Coarolina
    6
    Question Alignment Table = Sta: Northing Easting
    Hello,
    Would like some help and to know if this is possible.
    Trying to figure out how to make a Coordinate Data Table for alignment(s) that will pull out and display the Station / Northing / Easting for each major station along the alignment run.
    I would like/need to display this on each page for the stations on that page without doing it all by hand. (List each stations, and copy/paste way to time consuming)
    Example
    17+00 N=746402.7224 E=2041842.6256
    18+00 N=746323.4047 E=2041903.2926
    Thank you for your help!
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Default Re: Alignment Table = Sta: Northing Easting
    Currently, I can only think of a couple of ways to accomplish something like that.
    The first is not dynamic. It involves using a Report to dump out coordinates every 100' along your alignment, then use that report to create tables. The easiest way might be to copy the HTML report output, and "Paste Special" into Excel, and go from there.
    The other way is dynamic, and creates nice Station/Offset tables, but requires third party software:
    http://www.quuxsoft.com/SincpacC3D_DynamicLinks.aspx
    There's a link to a video demonstration of this latter option.
    Civil Engineering Moderator civil3Dguide's Avatar
    2006-01
    Temecula, CA
    281
    I was thinking about creating points along the alignment and creating a point table(s) but the points would not be dynamic either, as you would have to move them everytime the alignment(s) changed.
    I have not thought about that before, but it seems like there should an easier way.
    2004-02
    Colorado
    1,986
    Quote Originally Posted by civil3Dguide View Post
    I have something on the "To Do" list that will work better for this.
    But in the meantime, the Sincpac-C3D has something that sort-of works. You can lock Cogo Points to a position relative to an Alignment PI or PC, or a Profile PVI or PVC, so the Cogo Points follow edits. You can also link the Cogo Point elevations to the Profile, so the Cogo Point elevation changes if you change the Profile elevation. There's a brief demo here:
    http://www.quuxsoft.com/videos/LockToAlignment.aspx
  1. ID Northing/Easting In C3D
    By jimmyhill in forum AutoCAD Civil 3D - General
    Last Post: 2016-01-26, 11:00 PM
  2. labeling northing & easting on an alignment
    By Maverick91 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2012-03-29, 04:02 PM
  3. 2010: SETUP 2010 MEP DRAWING FOR NORTHING AND EASTING
    By SHOLLAND_CAD in forum AutoCAD General
    Last Post: 2011-09-30, 04:28 PM
  4. Northing & Easting
    By gmarshall.222707 in forum Dynamic Blocks - Sharing
    Last Post: 2009-08-11, 10:02 PM
  5. Northing/Easting snap to column
    By 4hoursstanding in forum Revit Structure - Wish List
    Last Post: 2007-03-13, 02:48 AM
