Results 1 to 7 of 7
Thread: open as read only
    2006-08
    636
    Default open as read only
    sounds like stupid question, i must miss something very simple, how to open rvt as read only? thanks.
    I could stop if I wanted to Paul Monsef's Avatar
    2003-09
    Everett, WA
    351
    Default Re: open as read only
    Quote Originally Posted by joe.zhou View Post
    ODD. I thought I had once just clicked the down arrow next to OPEN - now nothing happens.
    Yes, I see the same thing, the dropdown next to the open button doesn't work.
    2009-10
    154
    As I understand it the pulldown is for workset options, not for read-only. The equivalent of this in Revit is "Detach from Central," the check box to the right of the open button. In order to use this feature you have to first enable worksharing, which should probably be enabled anyway if more than one person is working on the file. If you don't want to do this you can always copy and paste the file into a different location, then open it.
    2008-11
    73
    Copying and pasting a Revit file within Windows Explorer is the same as creating a local file. The only way to get a separate file would be though Detach Central.
    2009-10
    154
    Yes, the copy and paste only works if you don't have worksharing enabled. Thanks for clarifying.
    2006-08
    636
    what if i not use worksharing yet (for instance at concept design stage and only one person work on it)? man, should Autodesk give us back that very simple/basic option?
  1. Open Read-Only: The ability to open a worksharing enabled file in a read only mode.
    Last Post: 2012-09-05, 07:02 PM
  2. Replies: 2
    Last Post: 2011-04-28, 02:04 AM
  3. Object open for read!
    By arshiel88 in forum VBA/COM Interop
    Last Post: 2010-06-10, 04:38 PM
  4. Open all drawings read only
    By aturgeon in forum AutoLISP
    Last Post: 2009-07-28, 01:31 PM
