Thread: Ceiling grids
    2016-01
    6
    Default Ceiling grids
    Problem:
    A project has both ACT 4*4 and ACT 2*2 ceiling tiles. I created the ACT 4*4 simply duplicating the ACT 2*2 but found out that I didn't really have any option to specify the grids shown on the floor plan even I tried to assign the hatch pattern to the newly created ACT 4*4 ceiling tiles. So it turned out that on the drawing, the ACT 4*4 had the exact grid distance same to the ACT 2*2, which obviously caused confusion.
    It looks like the ceilings have embedded grids assigned to the only types available in Revit: ACT 2*2 and ACT 2*4.
    Anyone has a solution to this?
    Thanks!
    Certifiable AUGI Addict cliff collins's Avatar
    2004-05
    St. Louis, Missouri
    3,135
    Cool Re: Ceiling grids
    Duplicate your 24 x 24 ceiling type.
    Then, you need to create a new material, called Ceiling Tile, 48" x 48" ( or something like that )
    You can go to Materials and duplicate the 24 x 24 material.
    Then give the new 4 x 4 material a 48" x 48" crosshatch model pattern.
    Then, in your new ceiling type--the 4x4, apply your new material under edit structure.
    I just did it and it works fine.
    cheers
    Cliff B. Collins, Registered Architect / BIM Specialist
    St. Louis, MO
    2016-01
    6
    Default Re: Ceiling grids
    Quote Originally Posted by cliff collins View Post
    cheers
    Hi Cliff,
    It worked! Thanks for the help!
    Wei
    2004-05
    St. Louis, Missouri
    3,135
    Glad to hear it!
    cheers
    St. Louis, MO
  1. Replies: 0
    Last Post: 2012-06-21, 08:48 PM
  2. Ceiling Grids
    By scompton in forum ACA General
    Last Post: 2007-10-25, 06:40 AM
  3. Ceiling Grids
    By mf in forum ACA General
    Last Post: 2005-06-04, 12:58 AM
  4. Ceiling Grids
    By rtcorpuz in forum Revit Architecture - General
    Last Post: 2004-10-14, 02:37 AM
  5. Ceiling Grids
    By bbcdude679694 in forum Revit Architecture - Families
    Last Post: 2003-10-15, 11:03 PM
