Thread: Revit Bug? - Split object randomly inherits properties of a split region within it
    2004-10
    Yorkshire, UK
    402
    Default Revit Bug? - Split object randomly inherits properties of a split region within it
    I often experience what seems to be a bug where by Split object randomly inherits the material properties of a split region within it.
    For example, I have a roof and use the split region command to show lead flashings. I use the paint command to change the properties of the split region to lead (the main area roof stays as its materials defined in type properties.
    Sometimes, randomly, the main roof area seems to inherit the material of the split region as if I have used the paint tool on the main area of the split object.
    This is not due to accidental use of the paint tool, or editing the object in any way. It especially seems to happen when working in 3D.
    I have reported to support and it does not seem to be a "documented or reproducable" problem for them.
    Does anybody else have a similar problem?
    Thanks
    I could stop if I wanted to Paul Monsef's Avatar
    2003-09
    Everett, WA
    351
    Default Re: Revit Bug? - Split object randomly inherits properties of a split region within it
    Quote Originally Posted by Andrew Dobson View Post
    Thanks
    This has happened as long as I can remember; which is why I opt out of using split regions. Editing the roof sketch or other various tasks can interfere with your split region boundaries.
    At least thats been my experience.
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Wink Re: Revit Bug? - Split object randomly inherits properties of a split region within it
    Best practice is to model 2 separate roofs- 1 shingles and 1 flashing.
    The split region and paint method will break apart when geometry gets edited/changed/moved, etc.
    Same for walls or floors with multiple materials.
    Don't split face and paint. Model individual walls/floors
    or stacked walls, etc.
    Learned these lessons the hard way about 6 releases ago.................
    cheers
    2004-10
    Yorkshire, UK
    402
    This is not a problem that is recognised by support, so if anybody else experiences the same thing, please post and I will direct them to this thread.
    NB: Editing the roof sketch is not the main cause of this prolem for me - its much more random than that. Today, I was editing an in-place family nowhere near the roof with the split face, and the roof material changed for no aparent reason.
    Many Thanks for the input
  1. split region tied to base constraint
    By shenderson in forum Revit Architecture - General
    Last Post: 2012-04-16, 02:57 PM
  2. Wall Split Region Vertically
    By sthedens in forum Revit Architecture - General
    Last Post: 2009-06-05, 09:16 PM
  3. Split Crop Region at an Angle
    By rahm in forum Revit Architecture - General
    Last Post: 2008-12-02, 09:55 PM
  4. Split region/Assign layers
    By Anthony Miguel in forum Revit Architecture - General
    Last Post: 2007-09-24, 12:55 PM
  5. Trouble selecting split region
    By Exar Kun in forum Revit Architecture - General
    Last Post: 2007-08-14, 06:22 AM
