Does anyone know if ASD can make a connection where one beam is sloped down and the other is flat so that the plate it creates stays square to the flat beam. I attached a drawing to clarify.
Joe
Joe
Yes ASD can make it. Use the appropriate macro. You can fine tune it manually if the macro does not do it exactly as you want. In that case you have to explode the generated connection.
