Thread: Viewpoint Control
    2008-11
    12
    Question Viewpoint Control
    Is there a way to control visibility settings of items in individual saved viewpoints?
    I want to hide items like floors or walls in some viepoints but not all. I would also like to change the color and/or transparency of items in some viewpoints without the changes taking effect in all viewpoints.
    100 Club crawfords's Avatar
    2009-07
    Portland, OR
    105
    Default Re: Viewpoint Control
    If you right-click the saved viewpoint and choose Edit, there will be checkboxes that allow you to preserve the attributes of the view, including the material overrides. A screenshot is attached.)
    -Crawford
    2008-11
    12
    I knew that it was something simple I was over looking. Thanks for the help.
    I could stop if I wanted to Teresa.Martin's Avatar
    2004-11
    438
    Smile Re: Viewpoint Control
    Hi. You can set this as the standard setting under Global Options>Interface>Viewpoint Defaults. Make sure that all the boxes are checked. This sets this as the default behavior so if you do hide something or change an objects color and save the view, it will save those settings. Of course if you change something in an already saved viewpoint, you need to right click on it in the Viewpoint Control Bar and choose update.
    Best regards,
    Teresa Martin
    Senior Application Specialist, IdeateInc
    Ideate on Youtube! http://www.youtube.com/user/IdeateInc
    Ideate Solutions blogs! http://ideatesolutions.blogspot.com/
    Check out my blog: http://bimnewworld.blogspot.com
  1. Points of a viewpoint
    By cadconcepts in forum AutoLISP
    Last Post: 2010-02-18, 12:27 PM
  2. Viewpoint Animation
    By harrymckinney in forum NavisWorks - General
    Last Post: 2008-11-17, 03:17 PM
  3. Reoccuring Viewpoint bug
    By neb1998 in forum Revit Architecture - General
    Last Post: 2006-07-07, 10:32 PM
