Thread: Revision Cloud
    2009-04
    42
    Default Revision Cloud
    Hi All,
    I have a problem with revisions. So here is my problem. I have two revisions on the same project (one sheet might have more than one revisions), but when we issue the drawing we want to turn off the cloud of revision 1 but leave on the tag and we also want to keep revision 2 with the clouds and the tag on.
    So I go to settings and go to revisions. I tell it for revision 1 to only show clouds and no tag. Then I tell it for revision 2 to show clouds and tag. Everything looks good on the first floor plan, but when I get up to the roof I want to be able to see the cloud and tag for revision 1 because we did no revision to the roof plan, but it doesn't show it because my setting were to only show the tag for revision 1.
    Any ideas on how to get the cloud to turn off and on per sheet?
    Thanks in advance.
    2009-04
    42
    Default Re: Revision Cloud
    I found out how to solve this, but it is a workaround. If you have to revision 1 and 2 cloud for addendum 1 (revision 1) and addendum 2 (revision 2), but you want to be able to turn addendum 1 off at the foundation level, but see addendum 1 at the second floor level.
    The workaround I found is - you would have to change revision 1 cloud to revision 2. Then you would create a revision 1 cloud (you won't be using this cloud for it will turn off anyways) - Then for the tag on revision 2, you would host the revision 2 tag to revision 1 cloud. This would change the tag to for revision 2 to 1.
    Hope this is clear.
    2002-08
    50
    Would switching your numbering to "Per Project" or "Per Sheet" help?
    2009-04
    42
    I am testing that out. I will follow up on what I find.
  1. Revision Cloud
    By jonblaze451 in forum Revit Architecture - General
    Last Post: 2012-04-28, 08:08 PM
  2. Revision Cloud
    By rhayes.99001 in forum ACA General
    Last Post: 2010-06-21, 04:56 PM
  3. Revision Cloud and Tag
    By techsupport.161645 in forum Revit Architecture - General
    Last Post: 2010-03-19, 11:41 AM
  4. Revision cloud properties in cloud sketch
    Last Post: 2009-02-01, 07:08 PM
  5. Revision Cloud
    By ljones.27809 in forum AutoCAD General
    Last Post: 2005-09-01, 06:35 PM
