Results 1 to 10 of 12
Thread: Material Editor
    2006-12
    Big "D"
    3,711
    Default Material Editor
    Has anyone figured out the new material editor? WTF???
    All my materials show gray in the editor like there isn't any image attached, but my realistic view shows materials correctly.
    I need to change a material and can't figure out what I'm supposed to do. The material edito has been the same for ages, now they decide to change it. This is so frustrating.
    2006-12
    Big "D"
    3,711
    Default Re: Material Editor
    Well apparantly you now have to double click the material swatch, which then brings up the material editor, which shows the material attached. But EVERY swatch in the material browser is gray, so you have to read the names or click on several ones to get the correct one. Totally retarded. I'm assumng the materials should show up in the browser, but they aren't. Maybe it's just me??
    EDIT*** Okay, other than the fact that all my swatches appear gray unless I make a change, then they show up in the browser, it actually flows better so far. I see the upside in it. Especailly if it's used from the beginning.
    2005-08
    99
    Quote Originally Posted by dzatto View Post
    I like it, much easier to use, with more friendly terms used for describing aspects of the material. Also, when you create a new material within the new system, it only gives you the items you need for that type of material IE glass will only show reflectivity and transparency in the editor, paint lets you choose the texture of the paint ect. I like it, so it might be worth it for me to sell 2011 to the rest of the crew here lol.
    2006-12
    Big "D"
    3,711
    Quote Originally Posted by Noahma2 View Post
    Yep, I noticed that also. Too bad I'm on my way to Revit.
    2005-08
    99
    Revit has a similar interface. I have not messed with the material editor in Revit too much. My original "material interface" wish for ACA was to be similar to Revit's.
    My office has not been able to justify taking the time and effort to move into Revit, so I think I will get to play with ACA2011 materials editor a bit more
    2006-12
    Big "D"
    3,711
    I hear ya. I'm the only designer in my office so it's an easy switch! lol
    Turlock, CA
    6,419
    I'm looking forward to it. If you want to create a new material. You first have to copy a material style, then go to acad's material editor to edit its material to match. This should bring everything into one environment.
    C:> ED WORKING....
    LinkedIn
    2006-12
    Big "D"
    3,711
    i still had to export it to an active tool palette, then click on it to bring it into the drawing so I could assign it to an AEC object throught it's edit dialogue box. That's the part I don't get or like. If I create a material, then I obviously want to use it in the drawing.
    Turlock, CA
    6,419
    Well, I still don't have 11 yet, so I'll have to wait and see. But from what I read, it is supposed to be easier.
    C:> ED WORKING....
    LinkedIn
    2006-12
    Big "D"
    3,711
    eh, I'm probably doing it wrong. lol
  1. 2013: Material Editor
    By Dr._House in forum Revit MEP - General
    Last Post: 2013-03-06, 08:24 PM
  2. material editor troubleshooting
    By cr_gixxer in forum Revit Architecture - General
    Last Post: 2012-11-14, 04:33 PM
  3. 2011: metric material editor
    By Peter Sedlacek in forum ACA General
    Last Post: 2011-04-11, 05:16 AM
  4. Material Editor Problems
    By herreraenrique201359 in forum 3ds Max - General
    Last Post: 2009-12-29, 10:33 PM
  5. Where is the material editor now - I hit M and nothing
    By twiceroadsfool in forum 3ds Max - General
    Last Post: 2006-01-25, 06:44 AM
