This is kinda hard to explain. I have an exterior wall on the second level that extends down past a first floor roof. In section, facing this wall, I need to see the exterior finish above the roof but not below the roof line. However, I don't just want to hide it using masking regions or whatever because the finish schedule needs to be correct. The only way I see accurately portraying this is to have 2 walls on the same line and modifying their profiles to fit the slope but then we run into revision errors down the road if the wall moves or the pitch changes. See attached for a rough example (disregard levels). Also, if this is done as a stacked wall instead of two seperate walls can the line between the two walls be changed?
