Thread: overlapped stepped footing please
    Member ddenton's Avatar
    2002-06
    Southwest USA
    45
    Default overlapped stepped footing please
    Revit 2010
    as in the attached image, i need the stepped footing to overlap shown in red. is this possible, and if so, howdya do it?
    thanks,
    daron
    Daron Denton
    Revit Architecture 2011 / 2012
    www.adept-dev.com
    100 Club jarosa's Avatar
    2008-03
    Wolcott, Connecticut
    104
    Default Re: overlapped stepped footing please
    Use an in place family.
    http://www.youtube.com/watch?v=ZsEeiIbdRPE
    http://www.youtube.com/watch?v=5wLfM...eature=related
    The videos show a similar footing. You can adapt your in place family to your needs.
    Another way to do it is to make several sections of a wall that is the width of your footing, then in a section or elevation view, grip edit the bottom and top of the footing down, and you can use the instance properties of the wall to fine tune the elevations of the footing, or use the align tool to align the top of the lower footing with the bottom of the upper footing.
    2002-06
    Southwest USA
    45
    Quote Originally Posted by dlister View Post
    works well. splitting the wall seems a bit clunky, but it gets me there. thank you.
    Daron Denton
    www.adept-dev.com
  1. STEPPED WALL FOOTING
    By dotrvt in forum Revit Structure - General
    Last Post: 2011-10-25, 08:02 PM
  2. stepped footing
    By jakob_k in forum Revit Structure - General
    Last Post: 2010-06-14, 03:20 PM
  3. Rebar in Stepped footing
    By jkh in forum Revit Architecture - Families
    Last Post: 2009-12-07, 08:35 PM
  4. Joining Material in Stepped Footing
    By ppirtle in forum Revit Structure - Families
    Last Post: 2008-12-19, 03:50 PM
  5. Help for Stepped footing of wall
    By ljupadhyay in forum Revit Architecture - Families
    Last Post: 2008-01-22, 07:10 PM
