Results 1 to 10 of 17
Thread: A starter Guide
    I could stop if I wanted to CadDog's Avatar
    2005-06
    So Ca
    439
    Default A starter Guide
    Hi everyone,
    I'm just about to install AutoCAD 2010 vanilla and
    wanted to get a checklist of things which
    I may need to know and do.
    I have worked with AutoCAD since 11 and
    have through the year create an AcadDoc.lsp which
    I changed and adjusted throughout the upgrades.
    In the AcadDoc.lsp I have system variables which
    I turn on or off depending on what our users needs are.
    I have also create a few lisp and VBA programs which
    through the years have been superseded by AutoCAD upgrade and
    no longer used or needed.
    Again, I would like to get a jump on things and
    any and all help would be welcome.
    Lastly, any heads up would also be welcome.
    I know that with any new program there maybe small problems.
    To that end, again heads up on what to do and set would be welcome too.
    Thanks like always
    CadDog
    My search code:
    CadDog2010starter
    2004-08
    Iron Station, NC
    3,198
    Default Re: A starter Guide
    Info I can offer:
    dont use migration
    in order for VBA to work, you have to download an additional tool from AutoDesk
    Dont forget to install Update 1.
    Drawing format changed in 10.
    That's about it, I just got done creating the deploy for 2011 a couple weeks ago. I cant think of anything else that I did in 11 that I didnt in 10, or in 9.
    AUGI Director scott.wilcox's Avatar
    2015-11
    Edmonton, Alberta
    990
    Apply your acaddoc.lsp content to acad2010doc.lsp.
    AutoCAD maintains acaddoc.lsp but will not disturb the one with the version (year) in the filename.
    EDIT: Oops, I got this backwards. (I put my lsp code in MNL files)
    Last edited by scott.wilcox; 2010-04-14 at 07:42 PM. Reason: got it backwards, sorry.
    Cairo - no, not Illinois
    5,069
    DO NOT CHANGE acaddoc2010.lsp ! instead do as you've done, and put your acaddoc.lsp in a folder on the search path. acaddocversion#.lsp will be overwritten if any service packs come along or if you have to re-install
    2004-08
    Iron Station, NC
    3,198
    Quote Originally Posted by scott.wilcox View Post
    I think you've got it backwards. acaddoc.lsp is the user created file that AutoCAD doesnt touch.
    2015-11
    Edmonton, Alberta
    990
    You are right, I got it backwards, sorry.
    2005-06
    So Ca
    439
    Smile Re: A starter Guide
    Thanks so far everyone...
    It was easy to update a few of my lisp...
    Ya, I couldn't load my VBA and
    read that I needed to download an exe file to how install.
    I maybe learning .net soon...
    I thought I need to use acad2010doc.lsp but
    in the doc it states to continue to used my AcadDoc.lsp which
    I need and it works great so far...
    Got my XRP lisp working as well which I'm very happy about.
    I don't know if AutoCAD is able to do what XRP does yet... I will check later
    Download a new iDwgTab which I don't understand why
    Autodesk haven't yet included this app... I love those tags...
    So far so good:
    My two major lisp programs are working
    and my one VBA program for creating layers on the fly is working great...
    My quick keys are all working but I need to continue to test and
    will not be passing the profile out until I'm sure everything that should work works...
    Now I be going to try my luck with my palettes menus which I created in 2008...
    Keep your ideas coming...
    Thanks again everyone it all helps...
    2005-06
    So Ca
    439
    Update:
    Here is what I have working so far:
    Below you find on the left hand corner iDwgtab and next to it VBA Quick LayerMaker
    Next picture shows the Lisp which sets all the company standard setting for Text and Dimension which also creates vb at selected scales. It also tags the drawing with the scale and notes it so the next user can quickly tell which scale was used...
    "O ya, and company name just for fun"
    2005-06
    So Ca
    439
    Also, and this is making me very happy so far...
    AutoCAD 2010 loads up very FAST...!!!
    Question:
    Are we still having the problem with Annotation Scale as we did with 2007, 2008 and 2009...???
    2015-11
    Edmonton, Alberta
    990
    2010 will prompt you when your drawing has a lot of annotation scales, asking if you want to manage them.
    Also, CTRL+C CTRL+V does not copy anno scales unless they are attached to anno objects.
  1. Motor Starter & Disconnect Switch Schedule
    By lmcgill2500924 in forum Revit MEP - General
    Last Post: 2011-09-20, 03:19 PM
  2. my starter questions
    By zoster_andrei in forum ACA General
    Last Post: 2010-02-15, 03:33 PM
  3. Revit Training - A Starter/Primer
    By dandlf in forum Revit Architecture - General
    Last Post: 2006-09-07, 07:36 PM
